Replacement for hydraulic cylinders
Old Jul 19, 2024 | 07:34 PM
AngusM22's Avatar
2004 CLK 500
I have just come into possession of a CLK 500 MY04. One of the hydraulic cylinders have just let go and has begun to leak. I found a few expensive options such as top hydraulics to replace but have notice they look similar to ones of other cars for cheaper. Is there any that fit? PN: 1649-030-B
Old Jan 20, 2025 | 09:36 AM
IilianaGoodman's Avatar
I did a bit of digging, and you’re right, some of those replacements can get pretty expensive. You might want to take a look at other models from the same manufacturer or even some different brands that could have compatible parts. I’ve seen people use hydraulic cylinders from the E-Class or S-Class that fit pretty well, and they’re often cheaper. That part number you mentioned, 1649-030-B, seems to be pretty specific, but I think there are some alternatives that could work with a bit of research. I’d say maybe check out a few online forums or even local suppliers that specialize in hydraulic cylinders.
