Clk w209 320 2005
Old Sep 17, 2024 | 03:25 AM
AdelDakdouki's Avatar
Clk w209 320 2005
I have a w209 convertible 2005 ,i opened the roof after this i want close it but he didn't work ,the car give me notification told the trunk is open but the trunk already closed
What i have to do ?
Old Sep 17, 2024 | 09:30 AM
jimyj's Avatar
E320
. A common cause for this issue is a stuck or faulty microswitch in the trunk latch mechanism. The microswitch signals the car's control module about the trunk's status; if it's stuck, the system may incorrectly think the trunk is open, disabling the roof operation for safety reasons. As a temporary solution, you can manually operate the convertible top by following the procedure in your owner's manual. To diagnose the issue further, use a diagnostic scanner like xentry or youcanic full system scanner to access the convertible top module and view live data. By manually pressing the various microswitches and observing their status changes on the scanner, you can identify if a microswitch is malfunctioning. Replacing the faulty microswitch should resolve the problem and restore normal roof operation.
