Complete replacement of the wiring and control modules
The problem is, my donor car has more features — front and rear parking sensors, keyless start with a start button on the shifter, a better radio, and seat ventilation.
If anyone has done this kind of job before, please share a link or any information. I’m worried I might need to replace all the wiring in the car, and it seems like a huge amount of work.
It seems like I will be investigating all this by myself like I did whith the roof. Almost ready to start. But my donor car is so perfect - it's literally like new, can't start disassembling it when I'm looking at it...
I will post here the progress, mb it might be useful for somebody in the future.
So the idea is to make one car out of two.
If there is any way to get that red one plated again, move parts from high mileage car over. Assuming you can get frame straightened.
My 2005 CLK500 has 54K on it. Crazy reliable. My biggest fear is a flat tire.
And yes, I can do the work myself, except for the frame and paint.
Let me attach a few more close-up pictures of the damage. I’d appreciate your opinion. The right rail needs to be replaced, and the left one is fine — it just needs to be pulled slightly.
What is done — all wiring harnesses and electronic modules are transferred from one car to another. And I can say for sure that if your car didn’t have a Keyless Go option, it would be easier to buy another car. Antennas and modules are everywhere, even the wiring in the trunk cover is different, because with Keyless Go you have a button on this cover to unlock the car.
The whole roof assembly was replaced with all hydraulics (without disconnecting any line or pump).
Of course, all the interior.
Today I tested the car without starting the engine — everything works, only two major issues: fault for fuel level sensor — circuit issue, will investigate later. And SRS service required, and this is bothering me because I used all components of this system from the silver car, which wasn’t in an accident. And it is sad that the scanner I have doesn’t show me the fault for airbags. I don’t know what to do with it, but will see.
The next step will be the engine and transmission swap. And after that, I need to find front and rear bumper covers with parking sensors, and this is difficult — I've monitored ebay for over a month already, and there are no available bumpers with sensors.
Everything from this car goes to another
I used a blanket to carry all this wiring - it is quite heavy for one man
in the middle of the process. The tricky part is - not to cut wires, do everything like from the factory
Without the convertible top
