Xenon headlight issues
Old Mar 21, 2026 | 03:06 PM
gatriphog's Avatar
Clk320
My 2005 clk320 A09 needs another headlight bulb big-xenon ds2; I had the shop replace the “module” in December and now the headlight is out again. What brand headlight bulbs have you had luck with?
Old Mar 22, 2026 | 07:36 PM
pomchal's Avatar
2015 S63 AMG Coupe, 2003 CLK500, 1986 TVR 280i
Bulb or Ignitor or ballast.
It is not common that the bulb goes out that frequently. Typically, the ignitor is the most frequent failure on Xenon headlamps,
first inspect the ignitor. Then switch the lightbulbs from left to right, to make sure it is in fact the bulb.
i have changed the igniters on both sides and the entire headlamps on both sides
never saw a bulb go bad.
Old Mar 22, 2026 | 09:29 PM
gatriphog's Avatar
Clk320
Will try. Thanks
Old Mar 24, 2026 | 03:18 AM
MacVidMB-V8's Avatar
W209, W124
I have had CLK500 since 2012.
Has HID. Have gone through 4 bulbs. 1 ignitor and 1 ballast.
When bulbs fail they typically flicker at first, start over and over.
A pothole took out a ballast (driver side, hard to get to) and it was one and done. Just dead. I then caught fire to ignitor by leaving no bulb in. It worked as advertised, and ignited.
Old Mar 25, 2026 | 08:03 PM
gatriphog's Avatar
Clk320
The headlight is now working with a bulb change it does flicker once in awhile,
