2006 clk350 cab: cigarette lighter fuse is good but no power
Old Mar 29, 2026 | 06:19 PM
btoenges's Avatar
I replaced the original radio with an aftermarket one in my wifes 2006 clk350. I used power from the cigarette lighter that is switched power. Everything was working great. I went on to other projects like installing new headlight buckets. After I got that job done I didn't have switched power to the cigarette wiring. I checked the fuse 15amp number 47 (or 46) in front fuse box and they are fine. If I connect radio to constant power radio works fine. I have been reading something about a possible relay that controls accessory power but can't find anything definite on that matter. Can someone help me sort out why I am not having switched power to the cigarette wire (blue with grey stripe). I haven't had any readings yet using the obd2 so I don't know if that will tell me anything. I have disconnected the battery and will reconnect tomorrow to see if that does anything.
Thanks,
Buck.
Old Apr 22, 2026 | 04:19 PM
wagzbenz's Avatar
CLK 350A Cabriolet
I had this problem, but haven't changed the radio. Those strips on the side of the cylinder were pushed inward, I got a small scewdriver and bent them out a little bit, works fine now. Hope that fixes your problem.
