Cold air intake
my 5-liter engine is shoehorned into an engine compartment that is probably appropriate for a V6, and it generates a lot of heat. Once it’s up the temperature, there is no cold air to be found !
the existing air box is reasonably thick and provides decent insulation. The air ducts pull air from the front of the car. Just keep the car moving and you’ll do as well as can be done.
Everyone pretty universally reports having problems with their MAF sensor after using K&N filters due to the oil. I'm currently running K&N knockoff filters from Amazon and SO FAR haven't had issues. They're at least cheap enough I can use them as disposables instead of resoaking them after cleaning. I may still be shooting myself in the foot with the MAF, only time will tell. Oh yeah, if you do mess up your MAF and cleaning it doesn't work, ONLY USE BOSCH to replace it.
