2003 CLK55 AMG Transmission/Driveshaft Heavy-duty?
The driveshafts on these models are 4" diameter.
(I realize that the up/down gear shifting is activated via steering wheel switches, and that the gears shift faster in the 2003 models.)
QUESTION:
Will the 2003 CLK55 AMG transmissions and driveshafts be the same heavy-duty?
Yes, the transmission on it is amazing. It shifts smoother and the electronics factor is very noticeable!
I think the transmission ( clutches and fly's) are controlled electronically ) drive by wire or something like that.
This was done for the 2001 & 2002 CLK55 AMG models (not the CLK 320 & 430 models), by using the transmissions from the S 600 V12, and providing the AMGs with a 4" diameter driveshaft.
The 2001-2 CLK55 AMG transmissions are heavy duty and the same as used in the S 600.
QUESTION:
Yes Karl, very good news for you! The transmission in the 2003 CLK55 will come from Maybach. The driveshaft will be at least 8" in diameter!
