Hi All,
Does anyone know the part numbers for the Brabus Lowering Suspension, (spring set only), to suite a CLK55 AMG 2006 Convertible? I have been told the front springs and rear springs have seperate part number due to the extra weight of the convertible.
Robertus
Robertus
Hi All,
For all members, I finally got hold of the part numbers for Brabus Lowering Suspension (springs only) to siut current model CLK55 AMG Convertible & Coupe. These springs drop the car approx 25mm -30mm
They are as follows:- Fronts 203-108-100 VA (max weight 1130kg)
Convertible, Rears 203-100-200 HA (weight 1055kg)
Coupe, Rears 203-100-201 HA (weight 1035kg)
Robertus
Robertus
I had the Brabus springs on my CLK500 when I got it but was disappointed how small of a drop there was and ended up getting coilovers instead. I can pull up some pictures of you want to see, but I would caution you to see some pics before commiting to the purchase and install.
Hi Frisco,
I had the amount of drop checked with Brabus in Germany, apparently they have 2 types of springs, one is a Lowering Suspension Set and the other is Sport Suspension set.
The Brabus dealer Melbourne, Austalia, said I would get a good 25mm which I am happy with, having 19" wheels and remember the CLK55 AMG is already lower than a CLK500 so it should be alright. Will post photo's once installed.
These are springs they put on there CLK61 Convertible and it looked pretty good
Also ordered the Brabus LSD (40%) as AMG will not supply theirs anymore which was 30%.
Robertus
Robertus
I know this is an old thread, but was wondering how your car looks lowered with the Brabus springs. Which one did you get, the lowering or the sport??
