I sometimes have a problem with the window opening again about 2" after closing. I found the only way to correct it is by disconnecting battery for a few minutes then going throught all the syncronizations outlines in manual.
You should be able to re-synch without disconnecting your battery.
I get that sometimes, usually in wet weather for some odd reason. Not a major problem at this time for me so I am okay with "once in a while". I think the dealership can help you with this.
Learso
Learso
To sync the window when it does not close properly removal of the battery cable was necessary.
This is a hall sensor timing problem. It might require new motor or new door control module. You should take it to the dealer.
Currently Active Users (1)
