Oil Change Problem
However, about 15 minutes on my way back home, the OBC indicated that I need to reduce the amount of oil in the car. Since then, I have only taken the car out about 4 times mostly on short trips. I checked the oil level today and it still indicated "reduce oil level". Not having a dipstick SUCKS.
My questions are:
1. How do I do reduce the oil level? My guess is the topsider oil drain pump?
2. How do I know how much oil to add (since the actual amount to fill will vary depending on how much actually drains out)?
3. If I continue to take the car to this shop, how do I ensure that this does not happen again?
I was thinking of just getting a topsider oil drain pump and doing the oil changes myself.
Who knows. It hasn't happened since on my other oil changes.
Does anyone know typically how many quarts of oil are added to the W209 CLK55 during an oil change?
9 quarts (start)
-7 quarts (if only one drain bolt was pulled)
+9 quarts (refill with new mobil 1)
=11 quarts
this happened to me. i went back to the shop and explained the situation. we basically just guesstimated draining 1.5 quarts, put the bolt back in, drop the car, check the oil gauge. pull more out, check the gauge until it says oil level ok.
there are pics of the drain bolts here (check post #18):
https://mbworld.org/forums/c32-amg-c55-amg-w203/179080-oil-filter.html
Hopefully my buddy with the topsider oil pump will be around this weekend and I can take out a couple of quarts.
BTW, how do you check the engine oil level during the oil change? I thought the engine has to run for a while and then you check it with the ignition in the on position? Is there another way to check it?
That is just my logic. I could be wrong. I would but a dipstick if they weren't so damn expensive.
My questions are:
