Tranny flush and Oil Change
Old Apr 30, 2007 | 02:51 PM
AMGEEZY's Avatar
2001 CLK55
Just got back from getting my trans serviced and getting an oil change. I don't know if the car feels any better, but I certainly do. We just drained the pan then took it off cleaned it, and put a new gasket and filter, then filled her up with about 4 liters of Mercedes tranny fluid. THANKS MBENZMAN for the help.
Old Apr 30, 2007 | 03:17 PM
Chappy's Avatar
AMG
Congrats! Mbenzman did mine a few weeks ago, along with the diff fluid.
Old May 1, 2007 | 12:49 AM
Zoom On's Avatar
'02 CLK55
If you drop the pan are you getting all the old out or is there some left in there?
Old May 1, 2007 | 03:07 AM
AMGEEZY's Avatar
2001 CLK55
No, it has a sealed torque converter, so it would require more work to get all the fluid out. I figured the fluid didn't lok so bad, so I will change it again in another 15,000 miles, but I won't change the filter. I'll change the filter every other time. Also I drove the car about 60 miles tonight and it shifts smooth, just like the day I bought it.
Old May 8, 2007 | 12:47 AM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
Originally Posted by AMGEEZY
No, it has a sealed torque converter.
It can't be sealed on the 55. My 430 has a drain bolt on the torque converter. You have to turn the converter 360 degree to find the bolt.
Old May 8, 2007 | 01:22 AM
AMGEEZY's Avatar
2001 CLK55
Your 430 probably is a 99 or 2000. They stopped putting in the drain bolt on the torque converter in late 2000.
