Will 245/35-19 fit CLK 55?
Old Oct 21, 2002 | 01:03 AM
2nerdy's Avatar
2001 CLK55
Hi all. I'm planning to put 19" 8.5 wheels on my CLK 55 and want to know these tires (245/35-19) will fit properly and what brand is good? TIA
Old Oct 21, 2002 | 11:34 AM
Timster's Avatar
2011 GL450
Size UTQG Max Max. Tread Rim Meas. Sect. Tread Overall Revs
Serv. Desc. Load Inflation Depth Width Rim Width Width Diam. Per
Load Rating Press. Range Width Mile
_________________________________________________
Stock Rear Tires are;
245/40YR17 _91Y _ _SL _ _220 AA A 1356lbs. 51psi 10/32nds 8-9.5" 8.5" 10" 9" 24.8" 840
__________________________________________________ __
245/35YR19 _93Y _ _RF _ _220 AA A 1433lbs. 51psi 10/32nds 8-9.5" 8.5" 9.1" 9" 25.7" 811
Stock Front Tires are;
225/45YR17 _91Y _ _SL _ _220 AA A 1356lbs. 51psi 10/32nds 7-8.5" 7.5" 9" 8.4" 25" 833
They look a little to tall, they may work but I bet they will rub.
Michelin Pilot Sports are a great tire, also the Yokohama and the new Bridgestone S03.
If this is to messed up I have an excel file that has all the currant tire sizes and specifications. Send me an e-mail and I'll forward it to ya.
(I will be out fo town for the next few days. You can also get this info iff the tire rack web site.)
Best of luck to ya,
Tim
Old Oct 21, 2002 | 06:26 PM
Mach430's Avatar
245s will not work without modification. On my wheels, I had to use spacers and pull the fenders.
Old Oct 30, 2002 | 07:38 PM
nuttertmf's Avatar
CLK 430
how do you pull the fenders?
