Help on lowering the CLK55
Old Nov 6, 2002 | 01:55 PM
burat's Avatar
clk55
I'm planning to change the CLK55 stock spring to an H&R spring. It'll lower the front by 1.0 inch and .9 inch on the rear (according to H&R specs). I'm still using the 17 inch monoblocks and will plan the change to 18 in the near future. Although the tires have been changed to 235/45/17 for front and 255/40/17 at the rears. Will this rub on the fenders? I really appreciate.
02 CLK55
Old Nov 6, 2002 | 03:58 PM
Larry Sonsini
Guest
Posts: n/a
I did the same thing....not a rub in sight
Old Nov 6, 2002 | 04:57 PM
burat's Avatar
clk55
Was planning to change the pads from 4 to 2 in the front and from 3 to 1 in the front. Will it still rub?
Thanks for the response.
Old Nov 7, 2002 | 02:01 AM
Larry Sonsini
Guest
Posts: n/a
I doubt it'll rub...I'm running #2's all around (My car started out with #3s in the front and #2 in the rear)
Old Nov 7, 2002 | 01:30 PM
Mach430's Avatar
2 front and 1 rear should be fine. As your shocks wear down, you may begin to have slight rubbing. That will be the sign that you need aftermarket shocks such as Kleemann or Koni.
