Question-Rear AMG Calipers
Old Apr 26, 2008 | 09:16 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
My 04 has silver AMG calipers on the fronts and standard calipers on the rear. Can you put newer AMG calipers on the rears to match the fronts? I think it would look a lot better!
Old Apr 26, 2008 | 11:35 AM
Peterclk55's Avatar
clk55 amg (209)
You certainly can! I did this with my 2003 car.
rear brakes
pads rear 004-420-49-20
rotors rear 171-423-02-12
left caliper rear 003-420-29-83
right caliper rear 003-420-30-83
Attached Thumbnails Question-Rear AMG Calipers-12008yhomemarchnewwheels-5.jpg
Old Apr 26, 2008 | 05:43 PM
LOVEMYBS's Avatar
Thank you!
Old Apr 26, 2008 | 08:46 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
rear brakes
Peter, those CLK63 BS rims are sick on your car! What tires are you running?
Old Apr 27, 2008 | 05:13 AM
Peterclk55's Avatar
clk55 amg (209)
Thanks. The tyres are 235/40/18 front and 265/35/18 rear on 8.5 and 9.5 rims with 3mm (front) and 10mm (rear) H&R hub centric spaces with the rear arches rolled.
My main problem is with tyre wear: The tyres in the picture are Goodyear Eagle F1 Asymmetrics but while the fronts are like new the rears have only lasted 4000 miles! I have got 6000 miles from Dunlop SP9000s and am just putting on Falken FK-452s to see if they are any better.
Of course I recognise that the car is hard on tyres as I have fitted Quaiffe Limited Slip Differential and changed the set up to be more balanced toward oversteer rather than understeer but 4000 miles!
I used to run the car on 19s which looked good but the ride was just too hard.
Attached Thumbnails Question-Rear AMG Calipers-day1240407.jpg   Question-Rear AMG Calipers-day1941240407-1.jpg
Old Apr 28, 2008 | 09:16 AM
LOVEMYBS's Avatar
More Rear Caliper Questions
I'm going to purchase these parts but would like to know if:
1) Did you notice any braking improvment,
2) Do these parts bolt up directly to the axel (e.g., calipers and rotors?),
3) Did you have to modify the hub or spindle,
4) Any problem with standard AMG 17" rims (e.g. offset), and
5) I see from your pictures the rotors are cross drilled, can I expect the same?
Thanks in advance for all your help!
rear brakes
Old Apr 29, 2008 | 06:02 PM
brabusw209amg's Avatar
1 V10, 2 V8
how much were the rear brakes?
