looking for diy lowering guide
Old Sep 10, 2008 | 06:58 PM
Foreverfortune's Avatar
2004 CLK55 cabrio, 2006 ML500
hi was wondering if anyone has any links to a diy guide for installing lowering springs only (H&R), for the w209 clk55. ive searched google and not much comes up in terms of guides. i have the macpherson spring compressor, but as it is my first time i am looking for a detailed guide.
thanks in advance for any help.
Old Sep 10, 2008 | 11:07 PM
s4avt's Avatar
'03 CLK 55
It's pretty straight forward, if you have done other cars... it is pretty much same.. I did with basic suspension work tools..
but you can find good guide on
MyMBONLINE.com
in DIY section
good luck...
Old Sep 11, 2008 | 06:21 AM
thanks, i ended up finding the vid of the c55 getting coil overs. i followed that guide, took everything off and got stuck on trying to release the top hat cause i didnt have the removal tool. tried to remove it with a flat head and hammer but it wouldnt budge so i had to stop before i severely damage the nut. i ended up putting everything all back together and now after several hours of messing around im back at square one lol. i'll try again when i find the tool.
Old Sep 11, 2008 | 11:40 PM
s4avt's Avatar
'03 CLK 55
oh that sucks,,
but I did without any special tool : (
what you need to do is get a hex tool and hold it while you are turning the net with vise grip.
good luck..
Old Sep 19, 2008 | 12:35 AM
MikeL's Avatar
Uber 202
spring compressor with an alan or torx will work also, u have to crank it opposite for the little ring to move. right is off and left is on.
