2001 W208 Maintenance suggestions at 67K mi
Old Nov 30, 2008 | 02:22 PM
Zal's Avatar
Zal
2001 CLK55
All, My Service B indicator has come on and the w208 is going into the shop. Considering I still have a few months of warranty on the car left I was curious to hear from you if there was anything I should have checked out specifically (in addition to trans mount and seat motors that I picked up from another thread).
The list below is all the maintenance I have had done. I am hoping you can alert me in advance of things that fail or what I should have inspected/changed based on the current mileage on the car (67729). I would like to avoid big surprises after the warranty runs out if I can. I plan to keep this car for a long time (or until MB makes a coupe worthy of replacing the 208!)
Many thanks in advance for the responses
Date Mileage Comment
17-May-08 63881 - Replaced Brake light switch
15-May-08 6470 - Replaced front rotors and pads and repacked bearings
15-May-08 63881 - Serviced rear differential
15-May-08 63881 - Replaced Engine V belt
15-May-08 63881 - Replaced rear brake pads
15-May-08 63881 - Wheel alignment
15-May-08 63881 - Fixed trans fluid leak in area of electrical connector. Replaced connector
15-May-08 63881 - Replaced lower control arm bushings
15-May-08 63881 - Replaced front engine mounts.
8-May-08 63750 - Replaced Spark Plugs
8-May-08 63750 - Replaced airfilter with K&N filter
4-Sep-07 59761 - oil change
4-Sep-07 59761 - De-carbon upper engine and valve train
21-Jan-06 52713 - Flex B service
21-Jan-06 52713 - Replaced both valve cover gaskets
21-Jan-06 52713 - Replaced both breather hoses for the left valve cover
21-Jan-06 52713 - Replaced steering shock absorber
21-Jan-06 52713 - performed evaporator cleaning service
21-Jan-06 52713 - Flush and replaced power steering fluid
21-Jan-06 52713 - Changed transmission fluid and filter
10-Mar-05 44732 - Flex A service
10-Mar-05 44732 - Air Mass airflow Sensor replaced
10-Mar-05 44732 - Renew coolant antifreeze
10-Mar-05 44732 - Fuel Filter Replacement
10-Mar-05 44732 - Replaced left and Right engine mounts
10-Mar-05 44732 - Replaced stop lamp switch
