rim for drag radial ?
Former Vendor of MBWorld
C55,SL55,C63
The rims weigh 20lbs each and with Hoosier DR"s they only weigh 37lbs!
Weld wont make wheels for us
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Based on a forum tip from Juicee63 I went looking for a 17x9 drag wheel. I wound up buying a pair of Rial Nogaro wheels sized 17x9 ET 40. They require a 15mm spacer to clear the rear brake caliper on my SL55 and even with the spacer the clearance is a scant 1 or 2mm. It couldn't be any tighter.
The Nogaro wheel with a 275/40-17 Hoosier drag radial mounted weighs 46 lbs. The tire supposedly weighs about 21 lbs so each wheel must weigh about 25 lbs. Not bad for an off-the-shelf cast wheel.
I was hoping to use my new setup at the March MIR track day but, alas, Wednesday doesn't work for me.
