W208 55 braking
Old Jun 16, 2009 | 10:57 PM
om84's Avatar
CLK 55 AMG
Exclamation W208 55 braking
I was wondering what are the best best stainless steel brake lines for and race brake pads (or race/street brake pad if such things is out there)
thank you
Old Jun 17, 2009 | 01:35 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Goodridge brake lines are one of the better brands. Make sure you don't get cheap ebay specials, get them from a local goodridge distributor.
I've had quite good results with EBC yellow brake pads (not a low dust option, but less than std) for both street and circuit track days. They have goos wear rates even at the track, minor dust reduction, low noise, good rotor wear (very important) and good inital bite with good even pedal feel.
There are others here that have tried other brands with success, there are a few good options available for you.
Old Jun 17, 2009 | 07:13 AM
Chappy's Avatar
AMG
I've been using the factory pads and rotors. They've held up well, but I normally don't run the car at 10/10ths....my skillz aren't that good ;-)
Old Jun 17, 2009 | 11:44 AM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
For pads I am using Hawk HPS series pads.
Vastly superior to factory pads and NO SOOTING!!!!!
Tire Rack carries them.
Old Jun 18, 2009 | 04:24 PM
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
I went with the StopTech Stainless Steel Brake Lines as the Goodyear were having leaking problems. Also, get some better brake fluid. I use ATE Type 200 Brake Fluid but doing it over again I would go with the Motul as it has a slightly higher boiling point. Check out- http://www.motorspotstore.com/mobrfl.html.
Old Jun 18, 2009 | 05:32 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
I agree, Hawk HPS are excellent performance pads for the street and have almost no dust. They dust less than Axxis Ultimates. Just make sure you apply anti squeal on the back & SIDES of the pad backing plate (most of the noise actually comes from the sides not the back of the plate).
Also, upgrading tires does help significantly in allowing the brakes to do their job so make sure you go with a high quality performance tire like a Direzza Z1 & etc.
Goodridge have had leaking problems so I would stay away from them, I'm surprised tirerack even carries them anymore. Stoptech line are the best on the market and are worth it.
Old Jun 21, 2009 | 10:50 PM
om84's Avatar
CLK 55 AMG
Thank you guys for your all help
