Rotora Big Brake kit on CLEARANCE!
Old Aug 5, 2009 | 07:47 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Hey guys,
There's a set available under clearance pricing for ROTORA BBK on your CLK AMG W208 & W209
Features:
-Rotora billet aluminum alloy piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Kit comes with 6 piston front & 4 piston rear with 2pc Drilled/slotted disc rotors, Stainless Steel brake lines, brake pads and hardware.
CLK CLASS (AMG) W208 & W209 F RBK149.02 6 FC6 355X32 2-PIECE $2,695.00 $1,886.50
R RBK098.02 4 FC4 355X30 2-PIECE $1,995.00 $1,396.50
**Sale price is on RED
Only 1 Kit available in RED and METALLIC BLUE calipers
PM/EMAIL/CALL ME if you have any questions or to place an order
Old Aug 6, 2009 | 05:26 PM
j--rho's Avatar
CLK55 AMG
What is the total weight savings over the stock brakes on a W208?
Thanks,
Jason
Old Aug 6, 2009 | 07:33 PM
neilbo75's Avatar
2002 CLK 55 AMG Coupé
"EXC AMG" means what? 'Except AMG' maybe? Are we sure these brakes will bolt on a 208 AMG? How does clearance compare with the stock AMG brakes? And the previous poster asked a good question: how much of a weight savings? Better or worse than the competing Brembo product? - or is this Brembo under a different banner?
Old Aug 6, 2009 | 07:50 PM
Sorry, That was a typo since I copied that from my for sale post on the CLK non amg section. Kits are available for CLK AMG and non AMG application, it's bolt on. I don't have the exact weight saving on the Mercedes calipers but for other applications it saves around 9-10lbs per side.
Old Aug 17, 2009 | 08:47 PM
1 more kit left on clearance!
Old Apr 2, 2010 | 09:23 AM
olie92's Avatar
CLK 320 1998, Honda Odyssey 2008, Honda CR-V 2007 (sold), Civic (sold), 1992 Accord (sold)
Is this still available? I m interested.
