MAS Air Flow Sensor?
Old Jan 2, 2010 | 01:33 PM
320ibimmer's Avatar
CLK430
Thumbs down MAS Air Flow Sensor?
My CEL keeps coming on and I'm getting a P170 code which indicates a bad MAS sensor. I cleaned it and the CEL came on after 1 day. Does anyone have a sensor available as i've been told it may not be the sensor and I don't want to pay for something not necessary.
Old Jan 5, 2010 | 11:19 AM
buffyclk500's Avatar
clk500
How many miles are on your car and do u have k and n filters in
Old Jan 5, 2010 | 01:09 PM
320ibimmer's Avatar
CLK430
My CLK is all stock (no K&N). It just turned 60K. I just changed the 2 air filters and cabin filter about a month before the CEL came on.
Old Jan 5, 2010 | 11:34 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
Probably will need to buy one. I believe you can buy a Bosch one for less than the MB badged one. Check it out.
Old Jan 6, 2010 | 02:21 PM
clk500
bosch makes the mass air flow for benz so it is the same thing just less i got over 100000 on my clk but i had k and n
i found on on ebay for cheap but my code was running rich
if u want go get a volt meter and test your maf with air going in to it u should read 5v
if u dont it is not workin
Old Jan 6, 2010 | 05:15 PM
j-mo's Avatar
2006 E55 AMG, 2019 BMW M240I xdrive coupe, 1969 Mach 1 Mustang
I just did the MAF in my 2002 CLK55. I was getting code 100 for MAF with the CEL. I bought a new Bosch one from AutohauzAZ for $150 and did myself in about an hour. It took a day for the CEL to go out and the car is fine now.
Good luck--
