tire size for w209 possible?
so I was looking at a 245/40/18 front and 275/35/18 rear setup I currently am running 225/40/18 and 255/35/18 with 8.5j and 9.5j
so what do you guys think and what would you recommend?
If using the correct spacers you shouldn't be breaking them! What's up with that!?
I think your tyre combination should be Ok. You might want bigger wheels later once you lower your car. 235 front 265 rear on 19's is what I run and seems to be the norm. Also depending on which tyre manufacturer you pick even though the tyre might say 265 it has a bigger tread pattern. Ask some of them as to how wide the actual tyre tread print is.
Has anyone run this setup before?
