Tire Size Problem
Old Mar 5, 2010 | 07:31 PM
Carnol4's Avatar
2003 Clk55
Tire Size Problem
Dropped my car off to the local tire guys. It has oem 17'' with stock 245/40/17 tires. Its also lowered with H/R springs. I was having them install 255/45/17 tires. When I went to pick it up, they said it was rubbing the strut....are they messing with me or did I screw up?
Old Mar 5, 2010 | 08:09 PM
CLK Masters's Avatar
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
whao. hold on a sec. did you want to put these on all around the car? or just the rears?
what brand of tire did you get in 255/45/17? different tires have different measures of sidewall thickness.
a 45 seriers profile on the rear is too big and it most likely will rub.
i run 255/40/17 on all 4 corners of my clk. I got another pair or rear wheels for the front to fit the tires.
in the rear of my car it doesn't rub unless i hit a speedbump at speed or have more than 2 people in the car.
our setups as far as the suspension goes, are the same. let me know.
Old Mar 5, 2010 | 09:12 PM
Carnol4's Avatar
2003 Clk55
the rear only-michelin ps a/s
Old Mar 5, 2010 | 09:18 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
I'm running 265/35/18's on the back and 235/40/18's on the front. Think 45's will be too tall.
Old Mar 6, 2010 | 12:29 AM
yea it'll rub, their not pulling your chain.
i ran it through a caculator
stock your car has 3.9 inches of side wall.
the new tire has 4.5 inches
diameter increased from 24.7 inches to 26.0 inches.
the tire is just to large for your setup.
Old Mar 6, 2010 | 08:25 AM
Carnol4's Avatar
2003 Clk55
Thanks for the input guys, much appreciated.
Old Mar 6, 2010 | 12:03 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Yes, the 45 is too tall to be combined with the 255 width.
When I was running stock 18" wheels, I went with a 255/35/18 set up. Hope this helps
Old Mar 24, 2010 | 10:37 PM
Carnol4's Avatar
2003 Clk55
ok lets try this again, returned the tires pretty easily thank god! Will the 255/40/17 Michelin PS A/S plus fit on the oem rims with a H&R drop? I really want to put a wider tire on the rim but dont want to the the spacer route if I dont have too
Old Mar 25, 2010 | 12:19 AM
ac_schnauzer's Avatar
can't say for sure about h&r springs but with coilovers you definitely need min. 10mm spacers. See exhibit A below
Old Mar 25, 2010 | 09:53 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
10mm front or back?
with stock wheels? ET...
Old Apr 5, 2010 | 12:27 AM
vegas55amg's Avatar
2002 CLK55 AMG Cabrio 2007 E63 AMG
I just got a new set of 18" Forgestars, was gonna put the same size as you on the rear, do u know anybody who has tried 245/35/18 on the front?
I looked up the specs, they are slightly wider than your 235/40/18, but overall diameter is slighly less, I was thinking they might look a bit more aggressive, but haven't seen any threads where anybody has tried it on a a W208.
thanks
