to Quaife or not to Quaife
Old Jul 4, 2010 | 10:06 PM
hami's Avatar
CLK55 '05 CLK320 '02
Well I have been trying to find out more information about LSDs and the difference between them. so far I am debating if I should get the Quaife or Kleemann LSD. I also have been trying to find out what differences are there between them but so far I can't find enough information that compares between them
thoughts?
Old Jul 5, 2010 | 12:15 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
It's definately worth added a LSD. You may think motorsport/performance driving but I found the biggest benefit was in wet weather and slipperly roads when cornering.
The Quaife LSD is one of the best out there. It's is a gear based unit (torsion type). Basicly it can provide upto 100% lockup (maximum traction), requires no special maintainence and the only way you would know you have it is by gained traction. It's NOT noisy and doesn't shudder.
The Kleemann LSD is basicly 2 spring loaded plates forcing against the spider gears in the diff. It wears, requires frequient oil changes and only provides upto 40% lockup. It's good if you have no other option for you car such as the C43's.
I would spend the extra and get the Quaife.
Old Jul 5, 2010 | 01:09 AM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
I have a Quaife in my CLK55 and my SL55 and can recommend as well worth the money.
Old Jul 5, 2010 | 10:49 AM
buffyclk500's Avatar
clk500
do they make 1 4 a clk500
Old Jul 5, 2010 | 11:03 AM
betrezra's Avatar
C63 507 AMG DA Car #19
I've got the Quaife in my CLK55 and I agree with above comments.
Can't really tell it was installed, except when you accel from a start around a bend you can feel the power transfer between tires catching grip.
I'll be able to comment more as I make some more power..... I've only got simple bolt ons now.
Prices are dropping on this LSD's now as they are phased out and the new stuff is en vogue......
Old Jul 5, 2010 | 06:31 PM
Ausmbtech's Avatar
Quaife don't, but try Kleemann, phatom grip (cheaper version of Kleemann) or drexler motorsport (german company).
Old Jul 5, 2010 | 08:09 PM
hami's Avatar
thank you very much for the info you made my decision way much easier
Old Jul 6, 2010 | 09:31 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
The clk500 differential should be the same as the 55. It is pretty easy to look up the differential and carrier in the epc and see if it is the same. I worked on a 2004 clk500 the other day that had the large diff in it. I have not checked but I would be about 99% on the qdf7v fitting.
Old Jul 6, 2010 | 12:06 PM
clkguy's Avatar
2004 clk500 coupe
quaife diff
i have been doing a bit of reaearch and have been lead to believe the QDF9V should fit the clk500 due to the 12 bolt ring gear
