Xenon Bulb Connector Problem
And received it yesterday. I cut the two wires from the ignitor and the aftermarket bulb connector and connected them.
After that, I decided to test them. Everything worked but after while like 3 minutes or less of driving, the right xenon would go out. This happened every time I started the car and started driving. Help? Did I attach the wires wrong?
Get rid of the wire nuts and tape...your connections show that you are a novice in electronic assembly practice.
Solder the wires together using a low wattage soldering iron, (no more than 60 watts) using a good rosin core solder, then remove the remaining flux by cleaning with isopropyl alcohol, then cover the splices with heat shrink tubing.
The hook up you have is okay for your light fixture in your home, but NFG for sensative electronics.
Thanks, I'll try it today and see how it turns out. I appreciate your help.
You mentioned that your bulb connector was burned.....it was burned for a reason.
I suspect ignitor failure.
Replace the bulb connector/ignitor assembly...
