More help power windows problem after ecu reset
Old Sep 27, 2010 | 07:41 PM
dohcfiend's Avatar
2001 CLK 55 AMG.......... 2001 Corvette Z06.........
Just as I expected the ecu reset removed the ses light but it caused another problem. Now the power windows think the home position is with the windows down about 2 inches. Whenever you open either door the corresponding window will roll itself down slightly. If u try to correct it with the door open it will just roll itself down again.
There is a fricken procedure for the windows?! Any help is appreciated.
Old Sep 27, 2010 | 07:57 PM
dohcfiend's Avatar
Nvm I found the procedure. Are there any more synchronization procedures I should be aware of after losing power?
Old Sep 27, 2010 | 09:21 PM
Chappy's Avatar
AMG
It's been so long since I've had to do this...you may have to re-synch the mirrors (they can be programmed to dip in reverse).
Old Sep 28, 2010 | 12:30 AM
dohcfiend's Avatar
Hey thanx. They seemed ok. I heard something of seat calibration. I went to drive it and it appears I have to call the dealer tomorrow to retrieve a code to re-activate the stereo. I'll keep ya updated as I run across things.
