Help trans sensor failing
Symptom: intermittently when the car is cold the display will not show what gear the tranny is in. It is not the display bc if I drive the car it will not come out of 1st. It does not set off a SES light either. Only happens when car is cold if I sit with ign in position 2 and shift some it will cone back on.
By your experiences; can this sensor be cleaned, adjusted, re-synchronized, re-calibrated or is replacement the only option?
