need spring pad info
I am in the process of putting new springs on my car but the dealer only list one set of pads but i hear of people using others.
I do not need to change the front any but would like to use a taller pad for the rear.
stock it has a 1 bump pad: i need the p/n for a 3 bump pad for the rear.
anybody help me out?
actually i forgot to subtract the 5mm on there so #4 for the rear.
210 325 04 84 pad#4 17 mm
either way will these 210 parts work on my 208?
Hope this info isn't too late:
(thanks to Wayfst)
MBZ makes pads in these sizes: 5, 9, 13, 17, and 21 mm and they designate them in their part #'s by numbering them 1 (thinnest), 2, 3, 4, and 5 (thickest). So if you look at the part #'s above that jives (second to the last dash #) with the measured difference in the ones that came off the car (stock ones).
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
(thanks to Wayfst)
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
