Command Center problem
Basically when I test drove the car the nav/radio worked fine at first. I turned off the car and back on and the command center kept shorting out like someone was playing with a wire or something. Over time when I drive it it seems to be hit or miss. Has anyone experianced this issue? Do I need a brand new command center? Should I look to buy an outside brand (looking to spend up to $1,000) If I go this route is there any brand or model I should look at?
Thanks for the responses any questions you have I will tyr to answer best I can.
