W208 Multiple Malfunctions
Old Mar 21, 2012 | 01:17 AM
AMG & Vette's Avatar
2002 CLK 55 AMG
Hi Guys. I was driving the 208 tonight when the BAS light came on. A few seconds later, the ESP light came on as well. I took the car home and parked it. It drove as normal. When I tried to start it and put it in the garage, the shifter was stuck in the park position. I used the pen trick to manually put the car in gear. I have to get out the pen whenever I want to move the car. Are these problems related? Is this something I could fix or is this a dealer repair? (I have average mechanical skills). Any help would be appreciated. Thanks in advance.
Old Mar 21, 2012 | 10:37 AM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
There is a brake light switch. I believe if it malfunctions you will not be able to take it out of park. Correct me if im wrong, it's been awhile since I had my w208 but you have to hit the brake to put it in gear correct?
Hope I am not confusing this with one of the other cars I've owned.
Old Mar 21, 2012 | 02:27 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Turning the wheel full lock to lock should reset the warning lights
Old Mar 21, 2012 | 05:39 PM
2002 CLK 55 AMG
Thanks guys. My research indicated the same thing: bad brake light switch.
Old Mar 21, 2012 | 08:53 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Yes its the brake light switch. Cheap fix. But the Throttle position sensor might be on the way out. I know this because when the switch was replaced the BAS,ESP light came on again.
