Odd, debilitating starting/not starting problem. Help!
My ’02 CLK430 had sat idle for 2 or 3 days. Went down to start it, she turned over just fine, idled, and then died about 3 seconds later. Tried again, this time the key would go to position 2, but would not engage the starter at all when turned to start. Hmmm…pulled the key out, tried to put it back in, the car would not accept the key at all. Tried to open the trunk, key no longer opens the trunk, or locks/unlocks doors. Used the key insert to manually open the trunk to see if the battery connection was bad. Perhaps the negative terminal was a bit loose. Disconnected/reconnected, key still won’t accept the key (by ‘accept’, I mean when you place the key in the ‘socket’ the vehicle grabs/locks in the key so you can turn it). Note: the dash and interior lights were on just fine, though after a few more tries, everything was dead.
Had to have the car towed to a shop. She gets there, starts up just fine right away off the truck. The shop said the negative battery terminal connection was loose, though it may likely be issues with wiring aftermarket stereo equipment (amp) in the trunk. Picked up the car from the shop, drove it around town, ran some errands, it’s all good. Go to leave for vacation, drive out of my lot, park it to grab the last item of luggage, car doesn’t start up. Had to have the MB roadside assistance give a jump. I drove it 90 miles just fine, parked it for a week, started it up just fine, and drove the 90 miles back home. I’m waiting for an appointment with a trusted local stereo/electronics shop to have a look as the previous owner I could tell had some aftermarket equipment installed (I could see a sub controller was still in place when purchased), though the supporting equipment had been removed (i.e. sock stereo in place, no extra amp, subs, etc – though I’m not sure if he botched any wiring in the previous owner’s install).
Note: The alternator is 6 months old, battery 3 months, MAF less than a year. Car reads no errors, MB tech that came out read that the alternator is working/charging properly. Until this issue, I’ve had some maintenance done on the car that the previous owner had not done – gaskets, brakes, etc – and she runs as if just off the lot. No problems.
Please help! I’m at a complete loss.
I shouldn't have made it to the dealership which was 30 miles away but I somehow did.
Dont know if your car may have the same issue but you never know.
Could be that you may need your key reprogrammed for the car.
No certain about the sensor - most of the time mine either cranks and turns over just fine, or locks out from even being able to crank (acts as if the battery is dead).
Do you have the emergency slim key?
