04 CLK55 P0440 CODE *HELP*
Old Mar 3, 2013 | 09:51 PM
rlddlr53's Avatar
09 C63 AMG, 05 C55 AMG
I have a P0440 code in my CLK55 and cant figure out what it is.
All the vacuum lines look good, no cracking, and I changed the gas cap off my c55 and the light will still come on.
P0440 exhaust gas recirculation flow
I changed the little ticking purge valve in the driver side near the headlight.
Old Mar 4, 2013 | 04:30 AM
elijah's Avatar
Euro Cars Only
Is your gas tank empty? Does it happen when the tank it full?
Old Mar 4, 2013 | 09:58 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I believe the 5.5 has dual egr with sensor they are on top and in the front of the motor.
The EGR sensor/valve might be at fault, try removal and cleaning with carb spray before replacement.
Research more "dont quote me on the fix just a hunch" quote unquote
G-Luck
Gator
Old Mar 19, 2013 | 03:59 PM
rlddlr53's Avatar
Small vacuum line to EGR solenoid was cracking. Replaced it and now perfect
Old Mar 19, 2013 | 05:44 PM
elijah's Avatar
Euro Cars Only
Good to know.
