clk55 amg 2005 wiring a radio
Old Jul 19, 2013 | 11:19 AM
Leutrim's Avatar
Clk55
Hey guys i have an 05 clk55 amg and i need the wiring diagram if anyone has it. I looked everywhere for about 2 weeks now and cannot find this. I have the ntg 2 navigation, the one for 05-08 clk cars. im looking to do an aftermarket setup because my amp burned out and i dont feel like spending 650$ for a used amp. thanks in advance
Old Jul 21, 2013 | 01:21 PM
Leutrim's Avatar
Clk55
anyone??
Old Jul 21, 2013 | 09:18 PM
tw2's Avatar
tw2
You will get a better response in the w209 forum. I only have experience with pre facelift installs. The easiest way is to just buy a wire loom for plug and play.
Old Jul 22, 2013 | 01:42 PM
HCUBED's Avatar
W209 2003 CLK55 Coupe
Old Jul 24, 2013 | 09:08 AM
Darren_0203's Avatar
03 CLK55 AMG, 02 C240
If you have the bose system and don't get a new amp you will have to run all the wires from a new head unit and tap them into the speaker outputs of the amp, or rewire all the speakers, which would be a nightmare. I've never seen an amp go for $650, usually around $200-$400 on ebay. I wouldn't bother doing any wiring and just get an amp unless you need to have subs or something.
When I got my 55 someone had a system in it and took it out before trading it in or whatever, they had tapped impedance adapters after the bose amps speaker output but had the input for the amp unplugged for whatever reason. I couldn't find a diagram either. Mine was an easy fix though. Good luck.
Old Jul 24, 2013 | 10:16 PM
Leutrim's Avatar
Clk55
thanks for the reply but i have the newer amp which goes in the 2005-2008 clk class and the cheapest one i found on ebay was 599.00
