MAINTENANCE QUESTION ABOUT MY LEAKY DIFFERENTIAL
Old Aug 30, 2013 | 12:46 PM
CLK55_NYC's Avatar
2001 CLK55,2003 CL55AMG,2003 E55,2004 CLK55,2011 E350
Ive got a 2001 CLK55(W208) and noticed that the rear differential is all oily.. took it to my mechanic where he put it on the lift. Ill need to drop the diff to change cover seal and it appears the drive shaft seals are leaking as well. The problem is that pretty much the whole rear-end has to come apart to access the diff and seals. My question is while I'm in there what else should I have done. I already have the 2 drive-shaft couplers.what else should I do? Any advice is greatly appreciated.
Old Sep 6, 2013 | 04:59 AM
nhmercracer's Avatar
Put a piece of clean cardboard under the diff. If no more than a couple of drops a week, leave it alone. Have the fluid changed soon, and have it checked every oil change, for three or four changes. They all leak. :-(
Old Sep 12, 2013 | 01:41 PM
rorf's Avatar
clk320 and sl320 V6
Check that the air breather on the top of the diff is not all blocked up with crud - common cause of leaking
Old Sep 15, 2013 | 03:48 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Find out where the leak is. I check for leak locations by degreasing the whole area, driving it a bit and then spreading talcum powder all around. Look for the wet spot.
Axle seals are easy to replace but I wouldn't mess with the pinion seal.
Old Nov 1, 2013 | 01:20 AM
E2233's Avatar
2000 E320 2009 E550
REAR DIFFERENTIAL SEAL LEAK
I noticed a small oil spot on the garage floor about a week ago. I cleaned the floor with a water and oil like material that looks like a gray gravel. I purchased a three pound bag from Home Depot a few years back.
A week later there was a small oil spot on the garage floor.
I have 61,000 miles on my E550. I purchased an extended warranty from MB 7 years and 100,000 miles at the time of my vehicle purchased.
Dealer Left Side Differential Seal Rear Differential was leaking.
Oil Seal replaced
Seal ring replaced
Sealant MB
Transmission Oil
Covered under extended warranty.
Old Nov 28, 2013 | 01:59 AM
E2233's Avatar
2000 E320 2009 E550
I saw another oil spot on the ground last week. Return to dealer replaced left side seal on rear differential again. Picked up vehicle today mileage 62,460.
Old Jan 25, 2017 | 11:52 PM
E2233's Avatar
2000 E320 2009 E550
LEAKY DIFFERENTIAL
Oil Seal replaced
Seal ring replaced
Sealant MB
Transmission Oil
11/27/13
1/24/17
Miles 94,160 Replaced both side rear differential side axle seals. I also had the transmission service at independent shop. The seals had some evidence of some type of adhesive or cyclone on the outer edges.
Attached Thumbnails MAINTENANCE QUESTION ABOUT MY LEAKY DIFFERENTIAL-seal-view-1.jpg   MAINTENANCE QUESTION ABOUT MY LEAKY DIFFERENTIAL-seal-view-2.jpg
