Opening bonnet without key blade
Help would be apprec
The fob will open the boot for battery access but not while drained, There is a jumpstart post under the bonnet but you are stuck again without indoor access.
From the outside I would hook up a battery charger @ the starter connection from underneath and go from there.
Good Luck, Gator
.My 208 is in battery is in the rear (boot) as most of the C, CLK class, The S, E, ML and other class battery were normally under the bonnet (hood).
If you are in the trunk then you capable of fishing for the door release with a firm type of wire through the rear.
Sounds fishy doesn't it.
Gator
Just notice the CLK 320, you are posting in an AMG forum with primarily V8 members, Builds are different.
