CLK Speaker Upgrade
Old Nov 26, 2013 | 02:11 PM
nikrox's Avatar
85 280GE; 2001 E55; 2003 CLK
CLK Speaker Upgrade
Is it possible to swap out my stock Bose speakers for updated Harmon Kardon ones? Ive got the standard headunit with the 6 disc cd changer in the trunk
would the sound system sound better?
Would i need to swap out the stock Bose amp with a Harmon Kardon amp?
Would i be able to add the Bose subwoofer in between the rear seats?
thanks
_n.
Old Nov 27, 2013 | 05:16 PM
Redcab's Avatar
CLK 63 AMG
I have both systems, the HK in my CLK 63 and the Bose in my W208. I was really looking forward to the HK system and it does have good sound, but far from impressive and in my opinion, it suffers from a lack of power. The Bose system gives up little, if anything at all in my opinion.
I'm considering amplifier options now. I don't want to damage the stock speakers, but in a car whose engine is without comprimise, it is hard to tolerate an audio system that does exactly that.
If you make a replacement, consider some other top audio choice that will fit in the same enclosures. My hesitation is with the command integration. I don't know what impact such a modification would have, or who to trust with an install.
Old Nov 27, 2013 | 06:58 PM
nikrox's Avatar
thanks for the feedback..... id like to keep it as factory as possible. i think changing the headunit takes away from the original look of the car. and i dont want to run all new wiring
does anyone know the specs on factory Bose AMP? does the Harmon Kardon amp put out more watts? and would the HK amp just be plug and play and work with my original factory headunit?
_n.
Old Nov 27, 2013 | 08:05 PM
sick430's Avatar
CLK Cabrio
hey,
I was contemplating the difficulty involved in this today. I took a buddies 650 for a spin and was so envies of just how much cleaner his audio system sounded.
Old Nov 29, 2013 | 07:40 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Guys there is a lot more on all of this in the Audio sub forum. That said I did replace the HU and the factory sub. The HU swap, Alpine really brought out clarity to the stock Bose system. It also showed the short comings of the stock sub. I found a sub, Helix, that fit the OEM sub horn and enclosure and the richness of the system came right out. If I decide to sell the car I can put it all back in about two hours. Any reputable pro installer can handle the job easily. I had the guys at Crutchfields do the HU install and I had the guys at Best Buy do the sub install. At best buy I was in an appointment line up of BMWs, Porsches and Volvo all having similar setups done. Just a thought. Good luck.
