clk55 w208 amg idling and accelerating issue. please help!!!
having a problem on my w208 clk55 amg all started after i cleaned the very dirty throttle body please check the videos and if anyone had this problem or any tips and advise would be very much appreciated
the idling acceleration problem is it doesnt do more than 4500 rpm and after 4000 it starts misfiring badly that it shakes the car
also the idling is rough the car can run fine for sometime and then you can feel the revs pushing up and you put it in neutral or in parking and the rev is playing up and down between 15-2000 rpm
so far i changed the o2 sensors maf sensor air filter cleaned the TB
anything else guys?
thanks
Per your other problem. Thats a little more complicated. Your problem with the idling came from you cleaning the throttle body and your problem is with the throttle body now. Its a electrical and mechanical problem. Your TPS is no where close to you throttle body.
and it did)))))) looks everything fine with TB and TPS
thanks to all of you guys who replied here
