Alternator or pulley
So I read most of your post on here voltage cold 12.3-12.5 ; idle 14.0-14.4 ,driving is the same 14.0-14.4 normal hits a 14.1/.2. Yes I will stil get that very suttle light fluctuating with idle. Would a new VR be necessary even with good voltage. I've been riding with it in my glove box. I finally found a good Indy I think to take it to to get tested. I checked for what grounds I could see I'm not sure where they are all located.
Thanks again
Did you actually change out the reg or just take it out and put it back in after stretching out the brush springs??? you state it is in your glove compartment, the new one? If so replace the reg with new one.
