CLK55 code: P1227
Old Jun 29, 2014 | 03:59 PM
cm60k's Avatar
CLK55 code: P1227
Guys,
After diagnosis my friend CLK55, code P1227 appears, it called;
"Exterior distribution shaft position sensor",,
anyone familiar what & where this sensor...??
ZAYED,,
Old Jun 29, 2014 | 11:14 PM
mguerrero's Avatar
w215 - CL55 w/stage III
I believe its one of the Crank Position Sensors - cheap fix!
Old Jun 30, 2014 | 07:01 AM
cm60k's Avatar
I think it's a part of air conditioning, isn't..?
ZAYED,,
Old Jun 30, 2014 | 11:18 AM
mguerrero's Avatar
ZAYED,,
Not the Camshaft Position Sensor ....
Old Jun 30, 2014 | 04:32 PM
cm60k's Avatar
As i know; camshaft codes should be: P0340/P0341/P0342/P0343/P0344, isn't..?
ZAYED,,
Old Jul 2, 2014 | 12:54 AM
c32kompressor's Avatar
CLK55 AMG
A P0 and a P1 obd code are different. A P0 code is a generic obd 2 code. In example: P0420
A P1 is a manufacturer code. Unless you have a scanner that is able to access this information, it will be hard to read.
