iPhone BT
Old May 17, 2015 | 01:28 PM
mguerrero's Avatar
w215 - CL55 w/stage III
Exclamation iPhone BT
alright, I have a w209 CLK55 with a Bose stereo system so I can't switch to an aftermarket nav unless I re-wire the whole care which I don't want the expense of - so, I my car has the phone jack in my center console .... how can I use that to connect my iPhone 6+ to the unit so I can take calls in my car and play my music??
I found an old thread about using an aftermarket unit to connect to it but it was quite confusing as to whether it actually works or not ... any info y'all can shed would be appreciated!
Old Jun 8, 2015 | 10:11 AM
andyncLI's Avatar
2018 GLA45 AMG, 2010 S63 AMG
Hi, I just got my iPhone 5s bluetooth connection working in my 2009 CLK550, so hopefully it works the same on you W209 CLK55. First check the "phone jack" in your center console, if it is a small piece (2 finger length) then it is just a base connector and you need to buy the MB bluetooth cradle. I bought mine from amazon from reggy275 for $195 used (MB dealer quoted $500, other amazon sellers are at least $100 more than reggy275). It came 2 days ago and I snap it onto the base connector, start the car, press the MB symbol on the cradle (start the bluetooth scanning) and check your iPhone bluetooth system (if you pair any phone to a car's bluetooth, you know what I mean), you'll see "MB phone system" come up and you need the pairing code (5-digit number, it's inside the cradle butt, you'll need to slide its butt cover off to see that code). It pairs immediately with my iPhone 5s and my son's iPhone 6, we both can make calls from the keypad on the dash and receive calls on car's audio system. Hope that helps.
Old Jun 8, 2015 | 01:20 PM
mguerrero's Avatar
you have a link? can't seem to find him - thx
Old Jun 8, 2015 | 02:12 PM
andyncLI's Avatar
Go on to amazon.com and search for "Mercedes-Benz MHI Bluetooth Interface Module Cradle Adapter". He's the 2nd seller with description of "Item in great working condition, OEM Mercedes Bluetooth adapter B6 787 5878", he ships out of OH, so no tax if you're outside of Ohio. Check out my post under W209 on "Bluetooth for my 2009 CLK550" and you'll see pictures others had posted.
