Heat Seat problem??
I just bought a 2003 CLK55 W209 from my friend. He said that the passenger heat seat stopped working first. The button does not light the LED's when you press it. About 3 months later, the drivers side was not working too - same problem.
Do you guy know what's the problem? Any suggestion to fix it?
Thanks!
If you come right pls lemme know what you did and how you did it. I think we are to start at the plug connector and then at the button on the dash but you need a special tool to remove the panel with all the switch controllers on them to check whats cooking behind there.
most of the time they can not be repaired and replacement covers are $$$
like others i put aftermarket pads in and given their limitations they are functional and cheap
I made a thread with pictures. https://mbworld.org/forums/clk-class...d-working.html
