Throttle/Transmission Issue
Old Mar 16, 2016 | 08:49 PM
Darylclk's Avatar
CLK55 AMG
Hello,
I have an issue with the button at the bottom of the pedal. The button that if you floor it you push. Whenever I push this while flooring it, I lose all throttle response. If I pull over, I can get a little delayed response after putting it in park, then back in drive. If I turn the car off and back on, it works fine. Works fine again until I floor it.
Does anyone know anything about this?
Thanks,
Daryl
Old Mar 17, 2016 | 11:07 AM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Sounds like symptoms of a MAF (mass air flow) sensor going bad. Get it scanned.
Other sensors will give this symptom as well.
Stored codes are guidelines for testing not parts replacement.
Cheers
Old Mar 21, 2016 | 09:47 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Its the throttle position sensor. I had this same problem. Easy fix and cheap.
Old Mar 22, 2016 | 08:41 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Anyone consider it could be the kickdown button itself?
Old Mar 22, 2016 | 07:33 PM
Darylclk's Avatar
CLK55 AMG
That is what I thought it might be. Gonna take another look at it this weekend, my buddy has a W208 so I might try putting his throttle position sensor in and see if it fixes it.
Old May 4, 2016 | 02:07 PM
cobrab19's Avatar
2003 clk 55
Sounds like the gas pedal assembly. Check that out as well
