CLK55 19" AMG wheels, Will they fit?
So i am new to this forum, some time ago since i made the profile but this is my first post.
I got some 19" original AMG III wheels i believe they are called, and i have no bolts for them, the wheels size are:
9,5j back
8,5 front
With Tyres:
265/30-zr19 back
225/35-zr19 front
(I might need 235 instead of 225(?))
My question is will they fit my 01 clk55 w208 without spacers and with the same original bolts that comes with the 17" amg wheels?
I could try but i figured i'd just hear out on here before i get workin.
Silver is my 55 with original 17"
Black one is my old 430, lowered and with spacers on it.
Cheers!
If you need spacers and longer lugs...get a quality set from like ECSTuning or the like.
The key here is the offset of the 19" rims. With a kind offset I'm sure the fronts will fit fine, the rears 'should' fit too with that wide tire; I've seen a 275mm tire on a 10" rim on the W208 CLK before with an offset of 25 mms with no spacers and no rubbing.
9,5j back
8,5 front
With Tyres:
265/30-zr19 back
225/35-zr19 front
Cheers!
