W209 55AMG Kleemann Injector SIZE?
Old Jul 21, 2017 | 08:08 AM
Chris Huynh's Avatar
W211 E55 amd W209 CLK55-kleemann
Just want to see what kind of injectors are you Kleemann, Weistec and any other type of add on blowers running. I'm currently running the yellow 285cc stock w209 injectors. Thinking about upgrading to the 55k black 390cc injectors. Will it help or different in power boost?
Old Jul 25, 2017 | 11:20 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Most are bumping up to 550cc available on Ebay they are Bosch supposedly.
I have a set for install on my own W208.
Injectors have migrated up into 750cc for Benz but way too radical for street. Tuning who knows?
Some of the elite ricers are in 1L but are making over 700hp with a turbo 4 cyl. Go figure.
Have a nice fuel map for Mitsubishi but it wont help much with Benz
See no harm in upgrading the injectors for preventative maintenance.
I have read a few posts about failing injectors bricking the engine.
Best, Gator
Old Jul 26, 2017 | 01:11 AM
Best, Gator
Ok, that's true. I used to own and tune Honda in the pass including boosting B-series engine and running over size injectors. Anyhow, I just purchased a set of Black M113K Injector running 395cc / 34lbs with my 10:1 Vortech FMU. I'm hoping the Ecu will cop with it.... I'm thinking about going with a 2.7" pulley for about 8psi of boost. You think this is a good idea for me to run 395cc injectors on 6psi of boost at 10:1 fmu for now?
Old Jul 26, 2017 | 01:18 PM
GatorMB's Avatar
I have a Bosh injector chart in PDF if it will help.
The stock ECU tune might work fine. Jumping up to 550. You should start collecting data from a wideband Gauge before throwing parts in the mix.
Do one mod at a time so you know if it was worthy. Eurocharged will enhance your tune for almost nothing if you have the original tune file available.
I can try to share the chart if it helps
Old Jul 26, 2017 | 03:38 PM
Thank you... that's great information. Can you provide me the Bosch Injector PDF?
Old Jul 27, 2017 | 05:01 PM
GatorMB's Avatar
Im still here, it is buried somewhere on another HD deep and helped me to decide on the 550s
Old Jul 29, 2017 | 08:33 PM
GatorMB's Avatar
pdf chart found
PDF found on one of my cell phones.
It is from a brother in AU.
