Brake light switch
Old Mar 14, 2018 | 09:34 PM
rgmrgm's Avatar
1986 300sdl
Brake light switch
I replaced the brake light switch on my 2002 CLK55 AMG and have a question. The plunger on the new switch is about 1/4 inch shorter than the old one. I read on one web site that these are made for multiple applications and the plunger length can be adjusted with a screw driver. I cannot see how to do any adjustment. I installed the new one and it seems to work fine no more abs, esp and bas warning lights. Do I need to be concerned that the new one is not the same length as the old one?
Old Mar 30, 2018 | 01:35 PM
rgmrgm's Avatar
1986 300sdl
My ABS, ESP, and BAS lights returned. I removed the brake light switch and the plunger is adjustable, forceful pulling or pushing will adjust the plunger length. I pulled it out to match the length of the original one and it seems to have corrected the problem. See how long the warning lights stay off.
Old Mar 30, 2018 | 10:01 PM
tannat's Avatar
CLK 55 AMG
I just did this job on my CLK55 AMG. I have no idea why your plunger was shorter. I did use an OEM part for replacement. It solved the problem. I hope your solution keeps the warning lights in check..
Old Mar 31, 2018 | 11:18 AM
rgmrgm's Avatar
1986 300sdl
Did the plunger length seem the same on the replacement. My replacement was 1/4th inch shorter when I first installed it and did not correct the problem, I adjusted it to be the same length and seem to have solved the problem.
Old Apr 1, 2018 | 05:18 PM
tannat's Avatar
CLK 55 AMG
I did not note the length but did note the mechanism on the new switch was much firmer than the one it replaced.
Old Apr 1, 2018 | 06:08 PM
rgmrgm's Avatar
1986 300sdl
min and max adjustment
Old Apr 1, 2018 | 08:10 PM
tannat's Avatar
CLK 55 AMG
The one I pulled off the car looks to have been at the max range. I can't recall how the replacement looked, but my brake lights are behaving now.
