CLK63 Caliper Mount
I have been doing a lot of research and it seems about the only parts MB does a great job at is hiding the caliper mount part number. If I were to purchase a new caliper would it come with the mounting bracket as one whole piece? I want to swap AMG brakes on my m278 E550 since they’re terrible to put it lightly. And, before I start doing turbo swaps and making big power I want better braking first. I know about c63 w204 calipers and getting an adapter, but the CLK63 non BS model share the same knuckle and my rotors are already 14.2” so if I had the part number it would be a direct bolt on. Any help is much appreciated!
brackets comes with caliper assembly,
what's the M/Y of your E550..?,
have to check if your knuckle uses M12 or M14 bolts,,
also, need to know for sure, what's the distance between your caliper 2 holes..??
-;ZAYED;-
I have a 2012 E550 coupe so it has the C chassis. I have compared the knuckle part numbers and they’re exactly the same. Which is why I would think the 2007-2008 CLK63 non BS AMG calipers should bolt right up, and since the CLK63 uses the 360mm x 32mm rotors which makes it even better I would think.
2008 CLK63 AMG non BS knuckles
Right 2043320201
Left 2043320101
2012 E550 coupe
Right 2043320201
Left 2043320201
As far as the distance I am unsure, I would think the same since it uses the exact same knuckles which the calipers bolt to. My current calipers are different, but I wouldn’t use the mounting bracket on my current caliper. I would use the mounting bracket on the CLK63 caliper that comes with them, if they indeed do. I think the C63 w204 have different knuckles which is why I would need an adapter. If I can just buy CLK63 with 6piston and bolt them on that’s a win/win.
your "C207 E550" sharing the same Front & Rear knuckles with "W203/W204/W209",,
means; 07 "Clk63" calipers & Rotors should bolt-on into your "E550"..
-;ZAYED;-
*for Fronts; you have (360x32) same as 07 "Clk63",
but your offset is (64.5mm), while Clk63 got (49.5mm),
*for Rears; 07 "Clk63" calipers & Rotors won't fit, cause "Clk63" spread caliper holes are (70mm),,
you will have to go with "C63" calipers & Rotors, cause spread caliper holes should be (90mm)..!
-;ZAYED;-
