TPS Sensor location? CLK 63
2005 Mercedes Benz CLK 500; 2007 CLK 63 AMG; 2014 E350; 13 Porsche Boxster
Update: So, the code is P2122 and says Circuit D low voltage. So, guess I don't need a sensor just one cable is bad right? Are the cables in the engine or near the pedal in the interior?
Hello. So just recently, my TPS sensor seems to fail giving up a code saying it is low circuit/signal. Just need to know where the location of it is? I kinda did see something on the right side that looked like it, but want to make sure before fiddling around there. I am guessing it is in the throttle body right? Thank you.
00 C200 & 00 C55 & 06 SLK55
I think you have bad faulty low circuit "Accelerator Pedal Position Sensor"..!
this sensor attached to acceleration pedal,,
did you replace it before..?
-;ZAYED;-
-;ZAYED;-
Ah, so it is in the pedal and not in the engine. See this is what I needed help with as all the parts and guides online show it being in the engine. After 2 months of waiting.. THANK YOU!
