Wrecked CLK500..CLK55 replacement advice??
For the 55, what year is it? Color? Condition? Maintenance records? Cab or coupe? All stock or mods? Wheels? Lots of variables to give a good price. If it's all stock, in good condition, with regular maintenance, $8-$11k would be reasonable. Main things I see mentioned to have checked are bushings (control arms, motor and transmission mount). Pretty cheap and easy fix if you're handy, though.
Headlight fogging is easy if it's only on the exterior - DA buffer or even a buffer pad for a drill and some polish (compound if it's really bad).
For the SRS, that's a bit tougher. If it was just due to a one-time electrical gremlin setting off the sensor, a good scan tool can reset it. If not, it could be a sign there was either an impact, or a sensor has failed.
Some folks seemed to have hijacked this thread.
other culprits can be a jambed seat belt latch.
SRS is easy if you inspect.
Best, Gator
If the spread of prices in your area is not great, I would consider buying the best maintained / lowest mileage car you can.
That is based on the fact that most people on a forum like this really like to take care of their cars and keep them to a high standard.
Glad you're safe .....and good luck with your search
I do think its great replacement for your car. They are so cool, and rare. I am lucky if I see 3 or 4 a year on the road and I live in a large city.
Good luck!
Good luck!
As to seeing them around, I've yet to see one in Oklahoma City. Hell, I barely see W208/W209 regular CLKs... Then again, this is truck country.
