2003 W209 Climate Control Wiring
Old Dec 11, 2019 | 08:00 PM
jimimonet's Avatar
CLK320
In the process of installing a new radio in my wife's 2003 CLK320 Coupe I kind of ham fisted the wood panel holding the climate control out and broke a small 3 wire connector going into the back of the climate control. I still have the connector but it is the type where your press the connector over the flat wire and the connectors pierce the wire to connect to the pins that go into the back of the climate control unit. I cannot re-press the wire into the connector. What I am looking for is the wiring diagram for this wire so I can cut and splice the connector back together. I have attached 2 pictures it is the small 3 pin connector on the right and the other picture shows the tag on the wire. What I need to know is the order of the wire relative to the 3 pins. Thanks.
