AutoTalent | Renntech Ecu Upgrade + Aero + Exhaust For Mercedes-benz CLK 55 AMG
Old Dec 13, 2019 | 02:45 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
362 HP @ 5750 RPM; 378 LB-FT @ 4000 RPM
Modified Performance
380 HP @ 5500 RPM; 395 LB-FT @ 3000 RPM
Renntech Performance Exhaust Headers
Click HERE to order Exhaust Headers!
RennTech stainless steel and ceramic-coated exhaust headers offer true bolt-on installation, mounting directly to the OE down pipes and all RennTech headers are hand built from mandrel-bent, seamless tubing and CNC machined stainless flanges. RennTech is use advanced computer aided design (CAD) and flow analysis software allows RennTech headers to deliver substantial gains across the entire RPM range. RennTech headers are constructed of the highest quality T-304 stainless steel and are ceramic coated to further reduce latent heat in the engine compartment as well as combat against thermal stress. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary SS Exhaust Headers offers incredible performance gains and rock solid daily driver reliability.
Features
Reduce latent heat in the engine compartment
Advanced computer aided design
Stainless steel exhaust headers
Ceramic coated exhaust headers
Long-lasting and driver reliability
Increases the performance
Incredible performance gains
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech Five Speed Transmission increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. Renntech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech 722.6 Five Speed transmission upgrade consists of a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings, electrical connectors as well as a new transmission pan filter. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Carbon Fiber Flat Top Airbox
Click HERE to order Flat Top Airbox!
RennTech Carbon fiber air box for the Mercedes V8 engine (M113/112). RennTech full carbon fiber airbox is more than just an impressive under the hood showpiece. By allowing a greater volume of intake charge air; our carbon airbox upgrade allows for greater horsepower and torque across the entire RPM range. The result is an additional 10 HP and 10 Lb/ft with increased throttle response and improved drivability.
Features
High quality prepreg carbon fiber construction finished
Greater horsepower
Greater torque
Gain 10 HP and 10 Lb/ft
Stunning good looks
Improved drivability
Renntech Carbon Rear Mount Dtm Style Wing
Click HERE to order Rear Mount Dtm Style Wing!
RennTech full carbon fiber Aerodynamic parts for the C209 CLK is the proverbial “cherry on top” and a stunning addition to the rear of the CLK exterior. Its unique design complements the refined trunk lines yet offers a more aggressive, stand-out look. RennTech Offering aggressive styling and functional performance; our fully adjustable DTM style rear wing is designed to work in conjunction with our carbon fiber rear deck lid spoiler and improves rear down force and stability at higher speeds. The rear wing mounting piece and uprights are a single piece, manufactured from T-6061 aircraft grade aluminum and our full carbon fiber wing element includes adjustable struts as well as machined aluminum end plates with the RennTech logo. The rear wing mounting plate with wing uprights attaches to the trunk lid via the included trunk reinforcement mounting plate. This allows the wing to bolt behind the license plate and can easily be removed or installed within 10 minutes.
Features
High quality prepreg carbon fiber finished
Offers a more aggressive, stand-out look
Durability and stunning good looks
Produces greater down force
Installed within 10 minutes
Easily be removed
Perfect design
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
Click HERE to order Renntech Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
Renntech Performance Package
Click HERE to order R1 Performance Package!
The Renntech R1 Performance Package is the Perfect Entry Level Performance Upgrade for the C209 Clk 550. The R1 Performance Package for the Mercedes 55 Series Engine Includes Our Proprietary Ecu Upgrade in Addition to Our Full Carbon Fiber Airbox Upgrade Which Offers a Larger Volume of Incoming Air for Better Engine Breathing and Improved Cylinder Filling. The R1 Performance Package Increases Performance to 385hp and 400tq at the Crank, Without Sacrificing Daily Driver Comfort or Reliability and Offer Huge Gains Across the Entire Rpm Range. Due to Increased Power and Boost Levels, 93 Octane or Higher Gasoline Has to Be Used With R1 Upgraded Renntech Vehicles to Avoid Damage to the Engine. This Combination That Provides Noticeable Increases Horsepower, Torque and Throttle Response Across the Vehicles Entire Powerband While Still Maintaining Daily Driver Reliability.
Features
Increases Throttle Response
Renntech Full Carbon Fiber Airbox
Stock Performance
362 Hp @ 5750 Rpm; 378 Lb-ft @ 4000 Rpm
385 Hp @ 5500 Rpm; 400 Lb-ft @ 3000 Rpm
Renntech Performance Torque Converter Upgrade
Click HERE to order Torque Converter Upgrade!
The RennTech lock-up clutch upgrade uses a multi-element clutch upgrade with additional layer of friction material between the clutch plate, better friction material on the clutch face and a larger surface area of friction material to help control slippage. This allows for better heat management and increased holding power. While slippage in the torque converter is important under acceleration, this slippage becomes a liability once cruising speed is achieved. The lock-up clutch controls this slippage and creates a solid connection between the engine and transmission. If the load on the clutch is too much, slippage can occur leading to excessive heat and wear.
Features
Larger surface area of friction material to help control slippage
Allows for better heat management
Increased holding power
Better friction material
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
