W208 AMG differential question.
Old Apr 30, 2020 | 05:54 PM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Hey guys, I probably should have looked or done this whole I had the subframe out. But there's a pretty extensive write up for a diy on a w210 rear differential bushings replacement. There is a top bushing at the front of the diff. Does ours have this as well? If so does anyone know the p/n for it? I'm unable to find anything for it!
thanks
Old Apr 30, 2020 | 07:37 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Yes, the 208 chassis has a single bushing offset to one side of the pinion on the front of the housing. I don't know the part number though.
Old May 1, 2020 | 11:52 PM
Quant's Avatar
2002 CLK55
i'll look it up for you tomorrow, i actually made the same mistake, replaced subframe bushings and then forgot about diff. i have the parts in storage, i'll check it out tomorrow.
Old Aug 3, 2020 | 02:04 PM
zwier.z's Avatar
A250 sport
Hello,
I bought wavetrac LSD for w211
then got 07 SRT8 rear gears
and modified the cover to fit the parts in
but im facing a problem with the bearings
IDK which would fit
